23 Aug 2022 01:23 PM
Just been set up with Sky. Connecting the printer, when I try to print, it prints a page that says at the top " Attenion. More than one access point/wireless router has been found that matches your wireless network name (SSID). If this is not intended your printer may connect to the wrong wireless network. to avoid this change the wireless network name (SSID) to be unique".
I am the sole occupier and user in the house, what is this all about? Surely it couldn't connect to somebody else's as the password would be different? If I do have to do it, how do I do it please?
23 Aug 2022 01:30 PM
By default the sky hub combines 2.4ghz and 5ghz wifi into one ssid.
You may have to seperate the wifi bands and rename 5ghz and allocate the printer to the old ssid which is now your 2.4ghz wifi
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
23 Aug 2022 01:53 PM
Thanks for trying, but I have no idea what your answer means!
