Discussion topic: Power supply
Message posted on 16 Jan 2026 09:24 PM
Power supply
I need a replacement router power supply. How difficult is that there is nowhere on this site to order a replacement everything is designed to get you to buy more sky services. All I want to do is talk to someone to get a new supply. The virtual assistant is worse than useless. Why is such a simple request so difficult. I'm using a temp supply but need the approved sky one. Will someone from sky please read this message and sort my rather simple problem that can't be resolved in a chat forum
Message posted on 16 Jan 2026 09:28 PM
Re: Power supply
Unfortunately no-one from a Customer Support contact centre will see your post here.
Message posted on 16 Jan 2026 09:29 PM - last edited: 16 Jan 2026 09:30 PM
Re: Power supply
I suspect 'replace Hub' is in its vocabulary, but 'replace power supply' is not.
Message posted on 17 Jan 2026 08:29 AM
Re: Power supply
@Mountainview Sky do not supply spares for equipment instead the procedure is to call Sky and the agent will arrange for a replacement hub with a power supply to be sent out. You can swap the two power supplies over and return the old one with the spare hub - irs up to you if you want to switch the hub or not Sky wont care. There will bea label to return the equipment at no cost to you.
