Discussion topic: Power light switches (green) on briefly
Message posted on 16 Nov 2025 12:06 AM
Recently, my Sky Broadband device power light switches on briefly upon turning it on and then switches off. Rest all lights are switched on and are solid green. WiFi is working fine with mobile devices but not connecting with my smart TV.
Message posted on 16 Nov 2025 06:50 AM
Re: Power light switches (green) on briefly
@Ammad1 unless you sre referring to a Sky hub as opposed to any extender pod thst is not normal and implies a serious fault and tge hub nedds replacing. However the extender pods shich can come with the WiFi Max psckage show no lights when connected and powered.
If you have the white hubs there is a setting which should enable your TV to connect. Sign into the My Sky app find the hub's advanced settings in the product options area and choose WiFi Security and change the setting to WPA2 as the default WPA3-T can stop some TVs from connecting.
