Discussion topic: WiFi outage
Message posted on 16 Nov 2025 02:56 AM
WiFi outage
Again a WiFi outage second week with not allowing WiFi
Message posted on 16 Nov 2025 05:40 AM
Re: WiFi outage
@Marples1959
Unlikely to be essential maintenance as it's a Saturday night Sunday morning.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
