Discussion topic: Power cable for Wi-Fi booster
This message was authored by TonyWind This message was authored by: TonyWind
I have the new Wi-Fi booster. It has a 12v power cable but I need an extension cable for it to reach the nearest plug.
However, I have bought a 5.5mmx2.1mm extension cable but simply DOESNT FIT.
It appears that the Sky fitting isn't the standard 5.5x2.1mm connector.
Anyone else have this problem ?
Do I have to cut the cable and make my own extension ?
This message was authored by Mini+Mo This message was authored by: Mini+Mo
Re: Power cable for Wi-Fi booster
Can't you just use a mains extension lead instead?
2.1mm X 5.5mm is the usual size, but there were some that are a different size, was a thread on this forum about it, some time  last year.
TonyWind
Thanks. Yes. Of course.  But didn't want all that clutter on a wall !
