Discussion topic: Wifi dropping out
This message was authored by mwf74 This message was authored by: mwf74
Wifi dropping out
Since Oct when Virgin installed their cables in my street I have had constant signal drop outs, mostly at similar times of the day. May be a coincidence?? I have had an alternative router which did not resolve the issue. I have had 4 Openreach engineers out plus dozens of calls to Sky about this. At this time I have literally had enough and considering cancelling after being a customer for 14 years. I have never had problems like this before. Any advice or similar issues with anyone. Very frustrated.....
Re: Wifi dropping out
@mwf74 cancelling with Sky and switching to any other isp using the Openreach cables means the issue will move to the new supplier. You could go with Virgin if you are out of contract or complain to Sky who are likely to release you from contract if they can't sort the issue. Note Sky have far lower complaint levels than Virgin according to Ofcom see https://www.ofcom.org.uk/phones-telecoms-and-internet/advice-for-consumers/telecoms-and-pay-tv-compl...
mwf74
@Chrisee thanks for reply. I was going to go with Virgin but their prices are silly. Its now and again it will drop and come back on, bout 2 or 3 times a day. Bearable I suppose but annoying. As mentioned this started when Virgin installed their cables in my street so I think they may have damaged something but its proving it. Im done with ringing Sky as they just keep sending engineers. If it gets worse I will have no option to go with Virgin as Sk y doesnt do full fibre in my areas
@mwf74 your problem is not with Sky but with Openreach who own and operate the network Sky and tge other isps use. If you post your hub's stats simebody msy be able to duagnose the issue . See Find your Sky Broadband router statistics
mwf74
Can anyone advise?
Router Statistics
System Up Time: 123:24:31
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 34257 47282 0 117797 978793 00:03:56 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 7596069 3957010 0 848 0 123:22:56 WLAN (5 GHz) Up 464202262 289051022 0 0 0 122:49:43
Broadband Link Downstream Upstream Connection Speed (Kbps) 35000 5597 Line Attenuation (dB) DS1:22.2    DS2:60.6    DS3:84.6 US0:8.5    US1:48.5    US2:0.0 Noise Margin (dB) DS1:9.0    DS2:9.1    DS3:0.0 US0:6.1    US1:6.2    US2:0.0
This message was authored by Dooth This message was authored by: Dooth
Love to know if anyone find a solution to this. Each eveing we notice around 7:30 when we flick over to Netflix, our internet drops. We have to keep resetting the box (which is what Sky Virtual help tells you to do). it works like most things when you turn it off and back on but I don't fancy making it my ritual every evening. Working from home is becoming tring as well, half way in the middle of a message or call the line drops out for no reason... Last one was today at 15:34...
Maybe someone on this community that work for Sky can give us a straight answer to the issues. Been with Sky over 25 years now and slowly looking to ditching it's service as I see no real benefit with all the other options at our door step.
