16 Dec 2023 06:32 PM
Hi,
I am getting the speeds expected through an ethernet connection, however sat right next to the router, I am getting significantly less, almost 10% of what I should be getting.
Router statistics:
WAN WANoE 1550042 5855357 0 289994 9482004 00:49:23
LAN Up 1835855 532853 13 2660256 302657 00:51:34
WLAN (2.4 GHz) Up 39349 3250 0 29926 225 00:17:33
WLAN (5 GHz) Up 633715 237188 0 15033051 462473 00:16:01
75000 kbps
Is this a router problem, if anyone can advise?
16 Dec 2023 06:35 PM
It could be a faulty router as both wifi bands dropped some 16-17 minutes ago
16 Dec 2023 06:48 PM
It would be quicker over the weekend to call sky on 150 from your sky landline or
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
16 Dec 2023 10:12 PM
The router stats show a solid almost 550Mbps downstream and 70Mbps upstream over the fibre, so the issue would be wireless that one is having an issue with and either the router is faulty as @cookiemonsteruk suggests, or you have a great deal of interference from a strong transmitter locally that is knocking the transceiver out on the wireless Sky router.
