Discussion topic: Poor wifi signal
Message posted on 28 Feb 2025 11:36 PM
Poor wifi signal
Message posted on 01 Mar 2025 07:30 AM
Re: Poor wifi signal
@Kimb82 probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up,to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
