Discussion topic: Poor speed
Message posted on 20 Dec 2025 06:05 PM
Poor speed
my broad band seems to be very slow
Message posted on 20 Dec 2025 06:23 PM
Re: Poor speed
@SkyAAXAV The sky service checker should be able to show were it is at!
Message posted on 18 Jun 2026 10:18 PM
Re: Poor speed
My broad band speed is very slow 300mbps
i pay for 900mbps.
My TVs are not working and I would like to watch the football !
Message posted on 19 Jun 2026 08:23 AM
Re: Poor speed
Presuming this is a wifi issue rather than a problem with speed to the hub, firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
