Discussion topic: Broadband keeps dropping
This message was authored by: TDTDTD
I've had a message to say the faster broadband is now up and running but it's been awful. It drops every 15-20 minutes
This message was authored by: Me134
Re: Broadband keeps dropping
Presuming this is the actual broadband rather than a wifi issue firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can give any further information if no success with the above, you can also use the MySky app.
https://www.sky.com/help/articles/broadband-diagnostic-start (run all tests)
It is important to run all possible tests on the above.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
