Discussion topic: Poor signal
Message posted on 18 Jun 2026 10:56 PM
Poor signal
The WiFi is very poor upstairs and now there is no signal on the tv upstairs
Message posted on 19 Jun 2026 05:32 AM
Re: Poor signal
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Message posted on 12 Jul 2026 09:30 PM
Wifi poor
The WiFi is so bad, have to keep turning my WiFi off on my phone otherwise the tv freezes. Bad signal now in the tvs in the bedrooms
Message posted on 12 Jul 2026 09:33 PM
Re: Wifi poor
@Jo353116 Did you follow any of the advice last time you posted?
Please see the reply to your last post above.
