Discussion topic: Poor connection
Message posted on 28 Apr 2025 10:06 PM
Poor connection
Trying to connect to my laptop in the kitchen. My neighbours WiFi shows a stronger signal than ours. Currently have a dot and no bars.
Message posted on 29 Apr 2025 06:52 AM
Re: Poor connection
@Lis2 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
