Discussion topic: WiFi speed
This message was authored by: Nickem1
WiFi speed
Poor WiFi speed on TV upstairs. Router is downstairs and TV downstairs is connected via Ethernet cable and is fine. Download speed on upstairs TV is between 2 and 20mb
Re: WiFi speed
@Nickem1 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
