21 Jun 2024 05:02 PM
21 Jun 2024 05:04 PM
Where is the pod located in relation to the Hub and the client devices?
Ideally it should be midway between them.
21 Jun 2024 05:20 PM
Hey, so we live in a bungalow and the pod is in the office with my laptop and the router is in the front roomm
I have tried to have it plugged in the hallway but get hardly any signal in my office when I do that.
21 Jun 2024 05:27 PM - last edited: 21 Jun 2024 05:27 PM
Unfortunately having a booster close to either end of the link achieves very little. They don't actually 'boost' at all: 'relay' or 'repeater' would be a better description.
21 Jun 2024 06:22 PM
Yeah problem is if I plug the Pod in half way I completely lose signal in the office
25 Jun 2024 10:54 AM
Posted by a Superuser, not a Sky employee. Find out moreIf that is the case you may need more than one pod or your solution isnt WiFi, its ethernet.
