Discussion topic: Poor broadband speed
This message was authored by: Ted3823
My broadband speed is at 13mbs and my gauaranteed speed is over 30 my speed
currently I can not Evan used Netflix
Re: Poor broadband speed
@Ted3823 Have a look see yourself!
Try running the line test here to see if any faults are found:
