Discussion topic: Poor WiFi strength
Message posted on 13 Jul 2025 04:40 PM
Poor WiFi strength
Hi our wifi has been poor for last couple of months. Sat boxes keep disconnecting,Netflix doesn't load/play reliably and our Sonos system doesn't connect properly either
Message posted on 14 Jul 2025 08:20 AM
Re: Poor WiFi strength
@SuzieDvs Before this happend have you changed any hardware within the property for your broadband. That is changing your router for a newer model?
Message posted on 14 Jul 2025 09:05 AM
No changes at all
Message posted on 14 Jul 2025 09:30 AM
I've had the same issue but going on longer. Sky then told me I was eligible to upgrade my router - hey sent a new one - and things have been even worse. The only thing that works is my husbands laptop as it's connected by Ethernet cable. I've bought a dual WiFi extender and done everything the internet can tell me to try and I'm at my wits end as I work from home 3-4 days a week and it's getting ridiculous. I'm about to order an extra long Ethernet cable so I can at least work!
Message posted on 14 Jul 2025 09:49 AM
Sorry to hear your experiencing the same. We've used all of our mobile data as the WiFi if simply non existent
Message posted on 14 Jul 2025 10:43 AM - last edited: 14 Jul 2025 10:43 AM
@Halfpint75 Do you still have the older router that you can put back in place of the new router?
Message posted on 14 Jul 2025 10:44 AM
@SuzieDvs Do you have a black or white router from Sky?
Message posted on 14 Jul 2025 10:54 AM
It is white. We switched to sky earlier ths year from BT, so it's new router from sky
Message posted on 14 Jul 2025 11:05 AM
@SuzieDvs Do you have a max subscription as part of your broadband subscription with Sky?
Message posted on 14 Jul 2025 12:01 PM
No we don't but we as working ok until just recently. Reluctant to be forced to upgrade as again it will only be a matter of time before the connection a poor
Message posted on 26 Nov 2025 11:13 AM
My tv keeps jumping off apps and app on my phone like to my home hive will not connect I have having to keep switching everything off and rebooting it
Message posted on 27 Nov 2025 10:45 AM
@Zoe163 Same question to the old post, black or white sky hub being used with your connection?
