Discussion topic: Poor WiFi signal
This message was authored by: LisaPip
Poor WiFi signal
I lose my WiFi signal when I'm in the rooms at the back of my house.
Re: Poor WiFi signal
@LisaPip Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
