Discussion topic: Phone WiFi
Message posted on 05 Jul 2026 12:04 AM
Phone WiFi
Can anyone help or explain why my Samsung s25 is receiving slow wifi from my router but my iPhone has a good signal
Message posted on 05 Jul 2026 06:23 AM
Re: Phone WiFi
@Anthig52 check the settings on the Samsung phone there is no reason why the Sky hub wont deliver identical speeds to both phones assuming yhry are in the same area in your home. There are numerous tips online about how to sort slow WiFi on the S25 but a reaset seems a sensible first step.
Message posted on 05 Jul 2026 07:10 AM
Re: Phone WiFi
I have tried all tips online to no success. I have the sky max hub
Message posted on 05 Jul 2026 08:28 AM
Re: Phone WiFi
@Anthig52 there are no technical reason why a Sky hub will give different speeds to two phones in the same area. Appreciate you say you have tried the online fixes but understand it is the signal strength thst determines the speed of the connection. I have checked the Samsung S25 is listed as WiFi7 compliant so is backwards compatable with the Sky Max hub's WiFi6 service.
