Discussion topic: Poor WiFi connection
This message was authored by: Don251
I have Sky Broadband ultrafast plus. I seem to have a good connection to most devices aside from my iPhone and iPad. When I have run the broadband/wifi checks it says the connection to iPhone and iPad is "poor" - the WiFi signal keeps dropping on these, which is frustrating. I've tried to turn off VPN but that hasn't helped. Any idea how I can improve the connection on these devices? Thanks
Re: Poor WiFi connection
@Don251 thecsignal strength depends on where the devicecis in relation to the hub and what lies between them.
Avatar for Don251
Hi, thanks for the response. I've tested the devices in the same room as the hub but ongoing issue. Any other advice welcomed. Cheers
