Discussion topic: Poor Wi-Fi connection to devices
Message posted on 20 Aug 2025 08:41 AM
Had full fibre installed on Monday 18th August and router was moved to back of the house. Since then , very poor Wi-Fi connection on all devices bar our Sky TV package. Devices keep losing Wi-Fi connection and can't download due to poor Wi-Fi connection
Message posted on 20 Aug 2025 10:54 AM
Re: Poor Wi-Fi connection to devices
@RuthMcCallum Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
