1
This discussion topic has been answered Discussion topic: Network conection
This message was authored by: p1pwe
Network conection
I am thinking to by how buy TP-Link Archer GE550 BE9300 on sky FTTP broadband How do you configure the router to work on SKY. Please advise
Re: Network conection
@p1pwe assuming you are in the UK (Ireland is different) its not the beat choice of router for a Sky line but it will probably work set it to use  DHCPv6 PD you do not need a log in string. Roughly 80% of Openreach lines support this method. If you search online you should find walk throughs for TP-Link routers.
