2
This discussion topic has been answered Discussion topic: Please Help. ASUS RT-AX58U connection to Full Fibre
This message was authored by: WhackyZack
Hi Folks
I'm at my witts end please help.
I'm in Ireland and have just had 1GB Full Fibre installed today , picked up the ASUS RT-AX58U router to try and get the most from the fibre.
Thanks to @cookiemonsteruk for the set up tips on a previous thread but
Unfortunately I'm such a novice that I can't seem to get the Asus to connect.
So far I've changed these settings
Username : anything@skydsl
Password : anything
Connection type: PPPOE
MTU is at 1492
Can't find Vlan id options anywhere.
I've attached some screen shots.
Thank you
This message was authored by: cookiemonsteruk Answer
Re: Please Help. ASUS RT-AX58U connection to Full Fibre
@WhackyZack
First image account settings
Username should be    anything@skydsl
Password should be     anything
Third image
Click iptv and enable and create a vlan id/vid of 10 in the internet field using custom/manual
@WhackyZack
Third image
Avatar for WhackyZack
Level 2 icon
@cookiemonsteruk Got it up and running . Thank you so much, you're a life saver .
