Discussion topic: Playstation wifi
This message was authored by elderwandninja This message was authored by: elderwandninja
Playstation wifi
i need to be able to cut wifi to the playstation at certain times.
Used to be easy with the Broadband Buddy app but that's obselete now
Is there any way to do this ?
Re: Playstation wifi
@elderwandninja
Unfortunately not. The best thing I can think of is you buy a 3rd party router with the controls built in
I am NOT a Sky Employee
elderwandninja
I ended up buying a Circle device and also a Ethernet splitter box. Why has the hub only got 2 ports on it ?
@elderwandninja
Not sure why Sky decided to only put 2 ports in the Q hub, my guess is that they were expecting everything to go wireless with their mesh system so you wouldnt need all the ports.
The new Sky Hub has 4 ports.
