Discussion topic: Pause wifi
This message was authored by: Ian1110
Pause wifi
How can I pause my WiFi at certain times and I can't remember or access my router to change passwords
Re: Pause wifi
@Ian1110
Controlling device access times over wireless is a feature of the WiFi Max subscription add-on.
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
Re: Pause wifi
@Ian1110
And resetting a Hub for a forgotten password is described here:
https://www.sky.com/help/articles/find-and-change-your-wireless-password
Avatar for Ian1110
Re: Pause wifi
That's not working
Re: Pause wifi
@Ian1110
Which bit isnt working?
I am NOT a Sky Employee
Avatar for Ian1110
Re: Pause wifi
Im trying to login using admin and password but its not having it
Re: Pause wifi
@Ian1110 if you have Wifi Max bundle the parental control settings are in the My Sky app where you use your Sky id log in. There are no parental controls on the older black Sky hubs.
