This discussion topic has been answered Discussion topic: PS5 + Sky Fibre
Message posted on 08 Apr 2024 10:28 PM
Hi,
Recently got a 500mb sky fibre line installed with a the new sky broadband hub. Whilst speeds seem to be fairly decent on speed checks sometimes fluctuating when I connect my ps5 through Ethernet cable down load speeds are averaging 150mbs. What I find strange if I do a hard reset on the router it gives me around 350mbs for a short while then falls right back down. It seems to me that the port is not allowing to run at full speed. Has anyone got this issue and do they know a work around?
Message posted on 17 Apr 2024 08:01 PM
I have finally resolved the issue.
I have a sky q hdr 2gb box and i was plugging this directly into the new sky broadband hub. When plugged in using an ethernet connection the q box limits all the ethernet connections on the router to around 150mbs as this is the max speed it can process. If you remove the ethernet and use wi fi the hub works properly and i am now acheiving the correct download speeds of around 500mbs.
it is frustrating the sheer volume of people i spoke to that were trying to sell me new products and simply were trying to get me go away by saying wait until the line has settled etc. frustrating that sky dont acknowledge this as a fault with their equipement and the answer from one of their employmees was just cancel your contract.....
Message posted on 09 Apr 2024 07:41 AM
Re: PS5 + Sky Fibre
@Lorty the server you connect to can control the speed and may be mimiting the bandwidth to allow more people to connect at once. If a reliable speed test shows the full bandwidth which for a direct ethernet cable should becaround 500Mb/s then your network is operating properly. If you use things like powerline adapters in the connection to the hub though they can limit throughput.
Message posted on 09 Apr 2024 10:10 AM
Re: PS5 + Sky Fibre
Hi I'm not using anything other than a direct 1.5m Ethernet cat5e cable
Message posted on 09 Apr 2024 11:53 AM
Re: PS5 + Sky Fibre
As a fellow gamer , I have discovered this is more than likely the Servers you are downloading from than your broadband connection itself.
I'm a PC gamer and I very rarely get a full speed download over my 900Mbit connection to the Steam servers.
Try downloading at different times of the the day if your able to as Server traffic varies.
Game servers as getting busier as it seems their slow at upgrading their CDNs the faster home internet connections get
Message posted on 09 Apr 2024 12:28 PM - last edited: 09 Apr 2024 12:34 PM
Re: PS5 + Sky Fibre
Realistically it's unlikely that such companies are going to be willing to invest the silly amounts of money required to permit users to saturate 500Mb and Gigabit FTTP whenever they wish.
Sometimes it's actually OK to expect people to wait a while for things.
Message posted on 09 Apr 2024 02:48 PM
Re: PS5 + Sky Fibre
Totally disagree with this. There is an issue with the connection that is causing poor speeds. Other people have no problem achieving high speed mine is capping at 130-150mbs so why can others get better speeds. I realise it won't be like that all the time the point is my line is only downloading at 150mbs when the line is handling 500mbs
Message posted on 09 Apr 2024 03:01 PM
Re: PS5 + Sky Fibre
Thanks, I have tried and it is just always running at around 130-150. Totally appreciate network traffic etc but other people get much faster downloads so what is holding mine back?
Message posted on 09 Apr 2024 03:02 PM
Re: PS5 + Sky Fibre
Probably best you come off these forums, someone here asking for advice if they know a reason for the slow speed not just you opinion of why I should just accept to be slower than other users.....
Message posted on 09 Apr 2024 06:15 PM
Re: PS5 + Sky Fibre
I don't own a PS5 but have done a little digging around
I'm not sure if you've connected your console to your WiFi connection previously but
the PS5 has a tendency of still using a wifi connection whilst an ethernet cable is connected.
This information is widely available through google .
if you have another device like a laptop etc which can do a wired speed test then this would be adviseable
If your speed test shows your getting full speed your paying for then that's great and hopefully it's a few settings
If your still low then I certainly be on the phone to sky and get them to sort it
Message posted on 09 Apr 2024 06:53 PM
Re: PS5 + Sky Fibre
Appreciate your help here. I have tried deleting and resetting up all the connections still no luck. I am going to try a cat6 cable instead of a cat5e but I really don't think that will help. If that fails I'll try sky again unless anyone else has any other ideas?
Message posted on 09 Apr 2024 06:58 PM
Re: PS5 + Sky Fibre
Your Cat 5e cable is not that capable with your speed
Good luck in resolving your issue ,
Message posted on 09 Apr 2024 07:00 PM
Re: PS5 + Sky Fibre
Sorry , Typo ,
Cat 5 e is more than capable to handle your speed
Message posted on 09 Apr 2024 08:08 PM
Re: PS5 + Sky Fibre
Yeah I know sky asked me to try it. So I'll try it.
Message posted on 30 Aug 2024 03:33 PM
Re: PS5 + Sky Fibre
Was just coming on here to try and fix my issue when I came across this.
had fibre installed yesterday.... was getting just over 500mb on speed tests, and just over that on both my ps5's in the house.
very shortly though the ps5's were only showing just over 150mb on the network test.
just unplugged the Ethernet from my sky q box, then ran the ps5 test.... 506mb!
this is crazy! It must catch so many people out!
cheers for this, you've massively helped out!
