Discussion topic: Internet not working
This message was authored by: EmmaMatt191
My Internet is not working showing 2 green lights and 1 red light
Re: Internet not working
@EmmaMatt191
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
