Discussion topic: PS5 Connection
Message posted on 18 Apr 2026 08:53 PM
PS5 Connection
Message posted on 19 Apr 2026 07:02 AM
Re: PS5 Connection
@Rachael79 wrote:
Why is the broadband not connecting to the PS5? Is there a limit to how many devices you can have connected?
There is a limit to the number of connections to all routers but it's really high so unlikely to be the issue.
Have you connected the PS5 previously OK? If so the go into the PS5 settings and 'forget' the currently stored connection and try from scratch. I see from your only other posts that you were getting lower case & different upper case letters mixed up (I do that all the time) so double check that.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
