Discussion topic: Issues with certain apps
Message posted on 18 Apr 2026 05:55 PM
Hi
i use a lot of gaming apps such as FSDT FSdreamteam for GSX on MSFS and sky seem to be blocking the app from opening to update ive tried a lot of apparant fixes such as disable anti virus and firewalls and creating exceptions through sky firewall shield and stuff but still it wont do what its meant too
Message posted on 19 Apr 2026 07:19 AM - last edited: 19 Apr 2026 07:21 AM
Re: Issues with certain apps
@NicolaR2026 wrote:Hi
i use a lot of gaming apps such asFSDTT FSdreamteamm forGSXX onMSFSS and sky seem to be blocking the app from opening to updateivee tried a lot ofapparantt fixes such as disable anti virus and firewalls and creating exceptions through sky firewall shield and stuff but still it wont do what its meant too
You had me Googling all of those acronyms to work out what it all is 🙂 Microsoft Flight Sim addonss for reference.
Sky broadband (or any broadband) can't stop an app from opening on your computer, it's possible that it's blocked access to what it considers or has been reported as a dodgy site (do you have Sky Shield by any chance) but honestly, try theFSdreamteamm forum and ask on there. There'll be vastly more experienced people on there who should be able to help.
Meanwhile, re-enable all of your security software.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 19 Apr 2026 08:09 AM
@NicolaR2026 sensible advice from @Me134 the only thing likely to block access from Sky's network is the Broadband Shield setting you can control via the My Sky app. See https://www.sky.com/help/articles/sky-broadband-shield-start
