Discussion topic: Sky Hub to Booster
Message posted on 04 Aug 2025 01:24 PM
Sky Hub to Booster
I've just received my Sky Max Hub.
I've connected my Sky Booster to it but the booster still has the old hub name so I can't connect.
Any suggestions?
Many thanks.
Message posted on 04 Aug 2025 01:28 PM
Re: Sky Hub to Booster
@shellyann123 the older Sky boosters will not work with the white Sky Max hubs which require a mstched pod that Sky will,supply if you subscribe to their WiFi Max package.
Message posted on 04 Aug 2025 01:54 PM
That makes sense.
thanks for the advice.
Message posted on 10 Jun 2026 03:49 PM
Just set up new Max Hub. Will my booster arrive automatically or do I need to ask for it?
Message posted on 10 Jun 2026 04:49 PM
If you have broadband max on your account you need to contact Sky about getting a pod (booster) sent to you.
Message posted on 10 Jun 2026 05:19 PM
Please can you tell me the best way to do that as I am going round in circles!! The help options do not help!!
Message posted on 10 Jun 2026 05:21 PM
You can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on this link:
