Discussion topic: PERMISSION TO WORK FORM
This message was authored by: HNORTH
WHERE DO I ACCESS OR DOWNLOAD THE OPENREACH PERMISSION TO WORK FORM TO LET SKY INSTALL MY BROADBAND?
Re: PERMISSION TO WORK FORM
@HNORTH see Here
@HNORTH
@SKY1992bf
Thats for MDU's (multiple dwelling units) for landlords flats and apartments. Don't know if its the same for single dwelling units
@HNORTH @cookiemonsteruk  on the same link under faq for residents in answer to q1 there's a separate form which should do the trick
This message was authored by: Eighteenth
There does not appear to be a form on that page for non-apartment buildings.  OR need the permission to work form to install Fibre on my property.
This message was authored by: mormegil
Openreach will contact sky to obtain your email address so they can send you the electronic ptw form or you can call sky tomorrow and they will supply the email address and OGEA reference so you can mail them direct
Thank you for your reply. This is exactly what I needed to do.
For anybody looking this up in the future, the key word you have to say to Sky's robocall is "engineer"
