Discussion topic: Outage in BH25
This message was authored by: Mark609
Outage in BH25
Does anybody know there is an outage in this area. It started on 23rd October, thanks
Re: Outage in BH25
@Mark609
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry again later).
