Discussion topic: Internet not working
This message was authored by: RG40
Our internet and wifi are not working
Re: Internet not working
@RG40
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry again later).
