Discussion topic: Outage SK3 Stockport
Message posted on 07 Jan 2025 09:23 AM
Have others then outed for two days in Stockport SK3?
Message posted on 07 Jan 2025 09:46 AM
Re: Outage SK3 Stockport
@Nitram4 best place to check is Sky's Service Checker in the My Sky app using a mobile connection. That should tell you if Sky are aware of an issue affecting your line if it doesn't call them to report the issue. Given the recent heavy rain and snow there are inevitably a large number of outages so things will take a whike to get back to normal.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
