Discussion topic: Our wi fi keeps dropping out today
Message posted on 21 Sep 2025 03:01 PM
Our Internet keeps going on and off today. We have reset it several times and disconnected and reconnected everything. Can you advise
Message posted on 21 Sep 2025 03:07 PM
Re: Our wi fi keeps dropping out today
@Cathmcc
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
