Discussion topic: My internet is not wroking.
Message posted on 21 Sep 2025 01:59 PM
Sky broadband is down first and now not working. Is there anyone who has idea about what's happening? I am from birmingham b16
Message posted on 21 Sep 2025 02:03 PM
Re: My internet is not wroking.
@Syed20
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Message posted on 21 Sep 2025 03:01 PM
Message posted on 21 Sep 2025 03:04 PM
