Discussion topic: Our broadband problens
Message posted on 09 Nov 2025 02:45 PM
Despite paying £38 a month we are having constant problems with our Broadband connection. Your service checker continuously tells us that our service is good whilst at the same time we cannot connect to WiFi.
Message posted on 09 Nov 2025 03:07 PM
Re: Our broadband problens
Not our checker @SAC4 You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
