Discussion topic: Optical Network Terminal attached to wall using adhesive tape
Message posted on 25 May 2026 11:26 AM
I recently had Sky Broadband installed... an Openreach engineer came round and installed the white internal Optical Network Terminal box. Affixed to the wall using double sided adhesive tape! Within a couple of weeks the box had fallen off the wall.
Anyone else had a similar experience?
Message posted on 25 May 2026 11:28 AM
Re: Optical Network Terminal attached to wall using adhesive tape
@andy1245 Bit of a cowboy job there, I would give Sky a call to get it rectified.
Was it Openreach or a 3rd party contractor like Quinn?
Message posted on 25 May 2026 11:37 AM
Will do! It was a company called MJQuinn.
Message posted on 25 May 2026 11:49 AM
That's no suprise, Openreach wouldn't do such a bad job.
Message posted on 25 May 2026 01:24 PM
To be fair i had MJ Quinn do mine at it was fine as it was nothing like that using tape as they made a neat job of it.
Message posted on 25 May 2026 03:12 PM
This is unacceptable defientely complain to Openreach as tehy are responsible, they will then laise with the subcontractor to arrange a solution. I cant see any reason why they would have that that in this case except laziness, also the hole where the fibre cable comes in is too big.
Sky Full Fibre 500mbps
Message posted on 25 May 2026 03:18 PM
@Tommy2 Openreach won't deal with the OP as they are not OR's customer, Sky is, they need to call Sky to get it rectified.
Message posted on 25 May 2026 03:20 PM - last edited: 25 May 2026 03:21 PM
@GD1 This isnt true actually, an Openreach subcontactor casued damage to my property during installation and whilst I have spoken to Sky and explained techincally Sky are they customer, I have a right to coplain myself, anyway I complained to Openreach directly and as a result the subcontactor has been liasing with me and as a result they are visiting tomorrow, you can make claims and compalints rirectly with Openreach.
