Discussion topic: Fill fibre broadband speed
This message was authored by: Jezkeith
Despite several telephone calls to sky, my Full fibre speed is only at 80 and reduced to 79.2 today on the mysky app.
The agents tell me to use another speed checker which shows 102. Google says these 3rd party sites are not a true reading.
Sky says they will credit me and look into why my app is not showing the so called correct speed. Any advice as sky are not getting back to me.
This message was authored by: Me134
Re: Fill fibre broadband speed
What speed do you pay for and how are you testing, the only reliable tests are through an ethernet connected device such as a PC or laptop. Not through WiFi. I use fast.com myself.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for Jezkeith
I am paying for minimum 90. As the third party speed checker shows 100 sky cannot see an issue. I just wondered why my sky app says different and sometimes says my speed is poor.
Avatar for Jezkeith
I am testing through fast as advised but via WiFi
@Jezkeith
Then the figure is for speed arriving on that device over WiFi, not speed delivered to the Hub.
