Discussion topic: My internet connection is not working
This message was authored by: Althear1
Cannot get any channels on the tv
This message was authored by: Tommy2
Re: My internet connection is not working
are you able to provide more detail please so that I can assist. Is it your entire internet or just on the puck ? if the latter than have you tried turning off the Sky hub and turning it back on again ? and ahve you checked netwrok settings and resetting them ?
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
This message was authored by: Carly551
I have no internet
Have you checked all connections ? do you have full fibre ? if so yous hould have an ONT, are you able to tell me is there a red light on the ONT or not or on the Sky hub.
@Carly551
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
