Discussion topic: Only 2 green lights no internet connection
Message posted on 18 Dec 2025 04:48 PM
Getting internet back on
Message posted on 18 Dec 2025 04:53 PM
Re: Only 2 green lights no internet connection
@Andrea142
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
