Discussion topic: No WiFi or sky working
This message was authored by: Rachaelbarr
Get it working
Re: No WiFi or sky working
@Rachaelbarr wrote:
Get it working
@Rachaelbarr
We can't help with that. You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
