Discussion topic: Oliver Craske
This message was authored by: OliverCraske
Oliver Craske
Wifi is not working. Consistently cuts out
Re: Oliver Craske
@OliverCraske
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
