Discussion topic: Not connecting to smart tv
This message was authored by: BeckH
Hello
recently joined your services and my bars whilst upstairs are only 2 I'm not happy with the buffering
Re: Not connecting to smart tv
@BeckH you are not talking to Sky by posting in this forum. However poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
