Discussion topic: Obsolete router
This message was authored by: JillyB63
Obsolete router
We've had a letter from Sky informing us our router will no longer receive security upgrades & we need to order a free replacement via their portal. There's nowhere to order one that I can see once signed into our account! I'd be grateful for any assistance if anyone has had the same issues. Many thanks.
Re: Obsolete router
@JillyB63
It's a genuine letter. I changed my Sky Q hub after receiving a similar email back in February.
There should be a URL quoted at the foot of the letter. When you go to this, there's a dropdown option to change your hub...
Take a look at your options:
Change your hub
Keep your hub and change your hub admin password
Switch to Full Fibre broadband
Add Sky WiFi Max
Here's the legal bit
If that doesn't work you'll need to call Sky to arrange it.
Re: Obsolete router
@JillyB63
The link should be there but if you can't find it then it is this one:
sky.com/skyhuboptions
Avatar for JillyB63
Re: Obsolete router
Thank you so much for supplying the link as it wasn't on my letter. Unfortunately, once I choose the "order new hub" option & sign in it then says "sorry that didn't work" & "The journey isn't available right now. Please try again later " & signposts the sky.com/help - which is no help at all. Looks like yet another phone call to India which after last week's call will be of even less help than the link but thank you very much for responding to my message.
Avatar for JillyB63
Re: Obsolete router
Thank you for responding, unfortunately the link falls over once I choose the "change hub" option.  Looks like I need to call India again althoughlast week's call was a waste of time.
Re: Obsolete router
@JillyB63 most Sky call centres are still in the UK
