3
This discussion topic has been answered Discussion topic: OPNsense router + FTTP without double NAT??
This message was authored by: oli-j
I have an OPNsense "router" (intel n200) and about to pull the trigger on Sky Broadband (currently with EE FTTP). Lots of long threads on this but no simple answers.
My setup plugs directly into the openreach modem/ONT and can support PPPoE and 'option 61'.
I realise I may miss out on any sky voice/VOIP service but that is fine.
Can this work without using the sky modem(e.g. some sort of modem or double NAT situation).
thanks
This message was authored by: mae-3 Answer
Re: OPNsense router + FTTP without double NAT??
@oli-j
The OPNsense firewall supports DHCP Option 61 and DHCPv6 PD and is fully compatible with Sky authentication. The authentication string for DHCP Option 61 is 'anything@skydsl|anything', and you will not have double NAT with this setup.
@oli-j
@oli-j
And the OPNsense firewall plugs directly into the FTTP ONT by ethernet cable.
Avatar for oli-j
Awesome, thanks for confirming this!
