Discussion topic: ONT with multi ports
Message posted on 20 Jan 2025 01:10 PM
I am a new customer waiting for installation of ONT in my premesis. I wish to know if the ONT supplied has single or multi ethernet ports .
Message posted on 20 Jan 2025 01:13 PM
Re: ONT with multi ports
Most recent onts have a single ethernet port to connect to the isp router
Message posted on 20 Jan 2025 01:14 PM
I believe all current installations are single port. Multiple port ONTs are only fitted where multiple services are ordered.
Message posted on 20 Jan 2025 01:15 PM
@cosmos Openreach normally install ONTs with a single ethernet port for domestic lines there sre various models used but customers get no choice . If later you order a second line then presumably the ONT is changed.
Given only a single router can be connected to a service this makes sense. Sky hubs offer 3 LAN ethernet ports and it is simple to add more using an Ethernet switch.
Message posted on 20 Jan 2025 01:21 PM - last edited: 20 Jan 2025 01:42 PM
Older multiport ONTs are a historical anomaly, as the deployment topology these anticipated never emerged.
As noted above, current ONTs almost always have a single ethernet port to link with an ISP router.
There's a newer model of ONT in Openreach stock which returns to having multiple ethernet ports, but this is for unusual premises with more than one FTTP broadband service.
Note that ONT ethernet ports do not have switch functionality, and cannot host devices other than routers.
The Sky Broadband Hub and Max Hub models have four ethernet ports, of which one is the WAN link to the ONT.
