Discussion topic: Now broadband modem replacement
This message was authored by: JVHollis87
I am looking to replace my Now broadband hub 2. Aware I could simply get a router and use that, but ideally want to replace the modem router all together. Signal is weak, plus always overheating. The actual broadband fine.
Looking for a cheap replacement. Wifi 6 ideally, with decent signal strength.
Happy to wait for possible sales as aware just missed Amazon prime day and now at the tail end of the sales.
Thanks for any suggestions in advance.
Re: Now broadband modem replacement
@JVHollis87
If you are wanting to replace everything completely then you'd need a router that can authenticate using DHCP Option 61.
I am NOT a Sky Employee
