Discussion topic: Not connecting to wif
This message was authored by: Billy761
My charm in the hallway not connecting and my alexa in the kitchen not connecting aswell .but my doorbell is connected.
Re: Not connecting to wif
@Billy761 do you mean "chime" rather than "charm"? Bring a phone near the chime and the Alexa to check that they are not in a spot with minimal WiFi signal. Assuming the devices have access to WiFi factory reset both devices, the makers weeb site should show how to do that. Then  try to connect them which often then works.
If the problem is poor signal level which does happen in many houses consider moving them to a better location or consider upgrading your home's wifi.
