Discussion topic: No wifi
Message posted on 30 Aug 2026 02:41 PM
No wifi
I've run the tests and the results say everything is working fine. However non of us can get onto the WiFi... which is ridiculous!!!
please help!
Message posted on 30 Aug 2026 02:50 PM
Re: No wifi
@BethBertrand
Firstly it’s worth pointing out that Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
