Discussion topic: Sky Hub keeps disconnecting for a few minutes at a time throughout the day
This message was authored by: Matt3789
I work from home still and have to use a vpn and randomly throughout the day and night i get a notification pop up to say mt ISP is restricing my internet affecting my connections. this can happen anywhere between 5-15 times per day. I know its not my works VPN causing the issue because i have my personal PC on at the same time playing music or other application running in the background and when i come to this at lunch or the end of the day i have multiple tabs on the browser telling me the connection was lost and then reconnected. Works laptop is on wifi and my PC is on ethernet cable.
Can anyone advise what i need to do to get this resolved?
Re: Sky Hub keeps disconnecting for a few minutes at a time throughout the day
@Matt3789
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Matt3789
Done that a few times and everything comes back as good. problem is when the HUB is offline it wont let me do anything until it comes back up in a couple of minutes.
How do i report it to sky?
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
Try saying nothing when spoken to by the bot.
This message was authored by: Storminorme
Hi,
My Sky Broadband has been doing the same thing also for no reason the router will drop connection flash orange for a bit then reconnect green.
have had router power lead and broadband socket and broadband lead all replaced today and has been on for about 6hours but has started to do the same thing again 😞 i am hoping it just trying to settle fingers crossed engineers have been from Openreach and Sky and confirmed all broabdband and connections are fine so really am not sure what to do next just wanted to let you know your not alone with this issue.
